    Thermostat problems
    I have a Carrier Edge non-programmable thermostat for dual-fuel.
    Stat works fine........but will make a call for heat immediately after satisfying. No down time.
    I cannot find where this stat has the ability to adjust to correct this problem.
    T-stat is in good location on interior wall and wired properly (I think). Has worked properly in past. equipment is 3rd-season in house.
    My furnace has not shut-off but for a minute or less, unless I lower temp on stat and wait for temp. to drop for a call for heat.
    I am an experienced HVAC guy who has never experienced this issue, good thing its at my own house.
    Any ideas.
    PS: I just bought this house.
    Lancaster PA
    Moved to Tech to Tech forum.
    Apr 2001
    Do you have the installation instructions? In the setup menu, make sure the settings reflect your actual equipment. Post a model and maybe we are allowed to send a link to the installation instructions. I think cycles per hour or anticipator is one of the settings.
    Jason
