Results 14 to 16 of 16
    Oct 2011
    Chicagoland Area
    It has a slight film of oil around compressor term housing but i was like ... how would it get all over the outside of the housing ??
    Because the compressor terminals are leaking. Not very common. More common on semi hermetics than tin cans, but I have seen it on hermetics. Have you ever come across a pump with the terminals blown out? Normally caused by plugged condensers.
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    Dec 2011
    Michigan
    I would suspect the Evap. But couldn't agree more add Dye and worry about it next time. Customer will appreciate that your in and out and there is a very good chance you will fix it next time
    Oct 2009
    cut unit to pieces, pressure test after finding leaks, put pieces back,replace cap tube, pressure test joints, evac, charge virgin, pinch access valves,
    Never fails
