    delaware
    1988 tempstar help
    trying to be sure this unit is a two ton hp
    model-ch5024vka1
    serial-l883574211
    found how to dcode serial but no luck with the model i am changing out my sisters condenser i know i have to add the expansion valve and external equalizer port on the suction after removing the metering device orfice but the new unit has 3/8 liquid but the old one is 5/16 will this matter much i know its a ten seer coil and it wont be as efficient but this is a workable replacement
    Virginia
    Quote Originally Posted by rj647 View Post
    model-ch5024vka1
    C- Condenser
    H- Heat pump
    50 - 5000 series
    24 - 24,000 BTUH Capacity
    V- Sweat/Valve
    K- 208/230-1-60
    A- Sales Code
    So yes, it is a two ton.
    delaware
    thx sir very helpfull info
