Results 1 to 8 of 8
    Dec 2011
    Question Gas fireplace fire goes out after @20 minutes but pilot stays on
    Heat-n-glo fireplace, fire goes out after a while (after 20 min or sometimes up to 1 hour) but pilot stays on. Problem started after Gas to the house had been turned OFF for the day. That was a month ago. Often it's not even fully warmed up (eg. 15-20 minutes) and other times an hour or two. So guessing it's not a heat sensor. Any air in the line should be looooong gone. Replaced thermopile 13 months ago. How can I eliminate the most likely possibilities?
    Aug 2011
    Ontario
    A few more details would help. Model # ? is it an insert or direct vent. ? Thermostat or switch ? Main valve is dropping out and pilot remains lit than I would lean towars wiring or gas valve. How old is the unit and when was it last serviced by a pro. ??
    There is no bad beer, some just taste better than others.
    Jun 2010
    Quote Originally Posted by JerryWoods View Post
    I have seen this before, I had to replace the thermopile again!
    Dec 2011
    check all wire connections, reconnect all spade connectors, if you have a "light switch" on the wall for turning the unit on and off. you may wanna replace that as well
    north carolina
    it may have a O2 sensor cutting it off. check to make sure it is getting enough air for combustion
    S.E. Pa
    Smile
    Deon, O2 sensors are "oxygen depletion sensors" which are special safety pilots used on ventfree gas appliances. The only ventfree appliances Heat&Glo makes are electric.
    Mar 2012
    Pacific NW
    Have you checked for a vent safety switch?
    Oct 2008
    Royal Palm Beach, FL
    Gas Pressure:
    Have you checked the gas line pressure to the gas valve? If it started after the gas meter was turned off, it could be a bad gas regulator in the gas meter.
    It could ne any of the things mentioned but you should make sure that you have adequate gas pressure. Is it Nat. Gas or LP?
    Its unusual that the burner stops but the pilot stays lit. If the thermocouple senses no flame, it shuts down everything. Its not supposed to leave itself burning.
