Trane Hyperion series 7 vs. 8
I live in Arizona and I am putting in Trane 20XLi heat pumps. My contractor is proposing to match them with the Series 7 Hyperion air handler. I am wondering if that is appropriate for a 20i and whether instead he should be matching it with the series 8 instead.
I would appreciate any thoughts and advice.
thanks.
with the tam 8 it would be fully communicating that's what I would want
TAM8's are slowly rolling out across the country but they may not be available in his area yet. I don't think we have any locally stocked in my area yet. I think It would be worth the wait for it though if you can.
 Originally Posted by k-fridge
The laws of physics know no brand names.
Will the 8 work with all outdoor units? In the past the 4TEEC worked with all A/Cs but only the communicating 20i heat pump.
Do you mean that my contractor can order it if it is not stocked locally and it just might take a little longer? I am in no special rush. The current units work and I just want to replace them this winter before the hot weather hits. So a delay of a few days or a couple of weeks would be no big deal.
I would think he could order it if you're able to wait.
That is incorrect I have used many 4TEEC units with XR15s and XB14's because they got better numbers than the 4TEEF units
In my area the TAM8 is not yet available and the TAM7 gets great HSPF numbers so it's kinda a trade off. 9.5HSPF and communicating or 10HSPF and non communicating. What is the tonnage of your unit?
Am I remembering it wrong? Maybe it was communicating gas furnaces that didn't work with standard heat pumps.
one 5 ton unit and one 2 ton unit
BaldLoonie the tam8 comes shipped for communicating only with Trane or American Standard equipment but there is a 24v accessory kit and can adapt to other 24v equipment.
Thanks everyone. My contractor is switching me to the Hyperion 8 series and we are upgarding the thermostat to the XL900.
get the xl950 thermostat! much nicer and way more options then the 900
 Originally Posted by JusTRANEing
Deleted Quoted text
Umm, have you guys been reading the problems with these stats? I have a few installed on communicating systems and :crossing fingers: they have been working but the non communicating systems... I stopped selling them until Trane works out the bugs. Yes they are amazing and look cool but they need some slight refinement and with the new B models they are supposed to work finally.
Yes the XC95M furnaces did not work with standard heat pumps without relay kits.
Reason: Edit QUote
- You may not post replies
- You may not edit your posts
Forum Rules
