Results 1 to 7 of 7
    Bedford,Ohio
    Cracked heat exchanger
    Neighbor had his furnace replaced because service man told him it had a cracked heat exchanger.
    I asked if I could have the old furnace for parts.
    I just wanted to test the heat exchanger.
    I laid the furnace on its back and filled the heat exchanger with water.
    Does not leak a drop.
    Is it possible to have a cracked heat exchanger and still hold water?
    thanks,
    david
    Grand Rapids, MI
    whats the model ? and age ?
    Could be failed and not cracked, like a plugged secondary giving off high CO readings.
    luck dan
    Jul 2010
    nebraska
    Quote Originally Posted by 6t7gto View Post
    No.
    Bedford,Ohio
    Marty,
    thanks for the reply.
    david
    Bedford,Ohio
    BTW it is a lennox 1991
    Jul 2010
    nebraska
    G20? If so they crack on the back side,first bend above the burners. Usually they'll show a rust line stress mark inside the exchanger at that spot for a few years then it goes all the way through. I have a couple on the first heat exchanger but most are on round two.
    Mar 2010
    NJ
    Just like a leak in any piece of metal, the crack can calcify or crust over and not actively leak. A water test is not always definitive.
    ecuacool
    732-494-HELP
    http://ecuacool.com
    Guaranteed energy savings.
    Serving all of NJ, NYC, and eastern PA.
