Results 1 to 7 of 7
Thread: Cracked heat exchanger
12-11-2011, 07:29 AM #1
- May 2006
- 19
Neighbor had his furnace replaced because service man told him it had a cracked heat exchanger.
I asked if I could have the old furnace for parts.
I just wanted to test the heat exchanger.
I laid the furnace on its back and filled the heat exchanger with water.
Does not leak a drop.
Is it possible to have a cracked heat exchanger and still hold water?
thanks,
david
12-11-2011, 07:52 AM #2
Professional Member*
- Dec 2004
- Grand Rapids, MI
- 497
whats the model ? and age ?
Could be failed and not cracked, like a plugged secondary giving off high CO readings.
luck dan
12-11-2011, 09:27 AM #3
- Jul 2010
- nebraska
- 1,166
12-12-2011, 06:30 AM #4
- May 2006
- 19
Marty,
thanks for the reply.
david
12-12-2011, 05:21 PM #5
- May 2006
- 19
BTW it is a lennox 1991
12-12-2011, 07:13 PM #6
- Jul 2010
- nebraska
- 1,166
G20? If so they crack on the back side,first bend above the burners. Usually they'll show a rust line stress mark inside the exchanger at that spot for a few years then it goes all the way through. I have a couple on the first heat exchanger but most are on round two.
12-14-2011, 05:53 AM #7
Just like a leak in any piece of metal, the crack can calcify or crust over and not actively leak. A water test is not always definitive.
