Thread: register vents
    Dec 2006
    register vents
    I have a 4 ton 12 seer unit how many register vent can i run off this unit?
    Aug 2011
    Lewes, DE
    thats a very open ended question....the answer is as many as you have designed your entire system (including duct work) for.
    butler pa
    usually 1 each per run
    Apr 2011
    SE Washington
    4 tons=1600 cfm, diffrent run sizes carry diffrent cfm, not number of, but what size to how many, if all were 6" at 125 cfm each, you could have a total of 13, then depends upon length and static and all that goes into a properly designed duct system
    Aug 2011
    Lewes, DE
    Quote Originally Posted by isuredo View Post
    in what world will a 6" pipe run 125 cfm?
    May 2008
    Missouri
    This is not a DIY board. You need to get an experienced HVAC person to install this. He'll know how to size the ductwork.
