Results 1 to 10 of 10
    I need to solder a 3/4 copper pipe that will run at about 50 PSI @ 180 deg F.
    It is my understanding that your average homeowners solder for copper pipe will not work.
    I know how to silver flos? (done it a few times) but dont know what the name of the rod I was using is called. Some type of silver?
    Can someone point me in the right direction here please?
    Thanks!!!!
    Cincinnati
    What's the medium ??
    Jul 2000
    Dallas,Texas
    That is within the realm of 50/50 or 95/5 plumbers solder used on hot water in homes and businesses every day.
    Hot water from a boiler...
    Going to a plate and frame heat exchanger
    Thanks!
    Silfoss
    Watts New, Ohm My, I been Electrically Commutated. Are U2.
    Oct 2001
    Stay-Brite is another solder that is the "same rolled" as 95/5 sold but rated for higher temps and pressures...flows the same...same flux clean pipes(flux)and give the solder a quick slide thru the sandpaper and dip it into the flux prior to hitting the pipe!
    "when in doubt...jump it out" http://www.youtube.com/watch?v=U1qEZHhJubY
    Cincinnati
    What they said. They're correct. Just act like a plumber. It ill hold just fine if you're good.
    Apr 2004
    Bartlett, IL
    A water boiler at 50 psi and 180F ????
    You're good at sil flossing? Are you sure you're not a dentist?
    LOL..
    "Good" ?? Umm.. its not rocket science eh? I didn't find it difficult to understand.. It was much more like welding that soldering. Now welding I'm good at I've done more welding than I can remember.
    Thanks for the info.. This site rocks!
    The 50 psi is for the other side of the heat exchanger.
    Sep 2001
    East Stroudsburg, PA
    Cold, wet, concrete.
