    Dec 2010
    Toronto
    defrost issue on johnson board
    I hope this is the right place to post one of my first questions...gotta built the 15 posts.
    Anyway, I bought a 4 ton 18 seer Hp for a client (Airease/FrasureJohnson group of products, York stuff I believe). I didn't buy an indoor coil and instead sized up a brazed plate condenser so i can heat water for floor heating. This is all working well except that it won't trigger a defrost.
    I had a Ranco15 defrost control from an old HP and installed it but the original defrost board doesn't like the open contact where the Rv was connected. I was thinking of putting a resister across the RV pins to fool the control but I'm not sure this will work.
    Has anyone had to make some adaptation to a board like this or know if the johnson board can be fooled by the resister?
    Dec 2011
    bedford ind
    sounds like you are wanting demand defrost. Do you have a board with time demand like an icp or goodman?
    Dec 2010
    Toronto
    Yes, it is a time demand defrost on a Luxaire HP. It is the only thing not working on this unit and i don't like the way the defrost is done on these unit anyway. I will eventually be programming my own control TAC, Reliable or KMC probably (not sure yet) so i really just need a timered defrost running on a bulb on the vapour line. The Ranco one I have is nackered. Anyone know what the current replacement is?
