Thread: Boiler t-stat
    Boiler t-stat
    I have a customer that wants digital t-stats for her boiler to replace the Honeywell round ones.. What is a good suggestion for a heat only stat that will work good on a teleydyne larrs jvh100n? There's not to many boilers around my parts so I'm just making sure I don't screw anything up. And this should be 24 volt system?
    southern IN
    I would use the Honeywell 5000 series. Can be set up heat only. Should work well.
    The first man gets the pearl, All the second gets is the shell
    Feb 2011
    Avon, Ohio
    Any of the Honeywell focus pro or vision pro stats will work. You'll just have to go in to the setup program and set them for hot water heat.
