Results 1 to 13 of 19
    Victoria,Tx
    Hmm
    I lived in the city, but had friends and cousins that lived in the country. They used Butane for heat, hot water and cooking. The storage tanks came in 150 to 200 gallon tanks, above ground. If that was butane, how did the butane come out of the tank when it was cold? They are called propane tanks now. How do butane cigarette lighters do up north? Just wondering. Roy
    Nov 2000
    Coastal Georgia
    They do bad when hit with a taser
    Paste this link to address bar if needed
    http://www.sun-sentinel.com/news/loc...-ftaser23feb23,0,5789285.story?coll=sfla-news-florida
    Nov 2000
    Coastal Georgia
    Roy, you put them in the ground in cold regions. Or to just get them out of the way. If a lighter is in your pocket, it will work.
    Victoria,Tx
    Hmm Yeah James, but here they are above ground
    It gets cold here every once in a while. I have seen it get into the 20's here before, for a day or two.
    Illinois
    They use a mix of propane, butane, and a couple other things here. Keeps it flowing in winter..
    You still see iced-up tanks when it gets really cold out.
    "If I had my life to live over again, I'd be a KA." - Albert Einstein
    It's later than you think.
    Nov 2000
    Coastal Georgia
    Then a good question would be at which temp does propane stop moving? This would mean the mass of the tank wold need to reach the temp.
    I have had the hand held bottles stop working in the teens.
    Illinois
    I don't think it actually stops moving.. Propane boils about -40º. Butane boils about +30º.
    I think the problem is that the tank doesn't have enough surface area to boil very much of at the lower temperature.
    I'm sure somebody will be along soon to enlighten us.
    Victoria,Tx
    Hmm Dang
    I guess we are talking about partial pressure now
    Victoria,Tx
    Hmm Ralph
    Butane will be a liquid at 50 psig at 100 degrees F. Propane will be a liquid at around 250 psig at 100 degrees F.
    Jul 2000
    Cuenca EC
    I don't know nothin' 'bout gas but........
    Here's a P/T chart for R290 (Propane).
    It would seem logical that the question to consider here is what is the lowest tank pressure allowable for a system to function? If say, you need 15 psig at the tank to make the regulator work and supply proper gas pressure to the furnace or appliance, then these things would work at around -21ºF. No?
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
    Victoria,Tx
    I found out a little more about butane
    Yes, They did use butane here in the South up until the mid 70's. And Ralph was right. Butane boils at 30 F at atmos. pressure. Propane boils at -45 F atmos. pressure.
    Victoria,Tx
    Hey ice
    I guess I will find a P/T chart for butane. Thanks Roy
    Nov 2000
    Coastal Georgia
    Back when you were a boy, they had just discovered propane.
