Results 14 to 26 of 26
Thread: Static Pressure
12-06-2011, 09:34 PM #14
Professional Member*
- Jul 2006
- Virginia
- 3,716
12-06-2011, 09:39 PM #15
Nice. Have you inspected your ductwork lately?
Always here
12-06-2011, 09:47 PM #16
Yes! If the supply pressure is too low you probably won't have a high enough velocity for proper and even diffuser throw or duct distribution.
Return should be as low as possible."The only true wisdom is in knowing you know nothing" Socrates
12-06-2011, 09:50 PM #17
- Apr 2006
- 80
12-06-2011, 09:57 PM #18
Leaks
Always here
12-06-2011, 10:28 PM #19
- Apr 2006
- 80
12-06-2011, 10:52 PM #20
- Apr 2006
- 80
12-07-2011, 05:00 AM #21
12-07-2011, 08:38 AM #22
- Feb 2010
- Landis North Carolina
- 528
12-07-2011, 08:58 AM #23
beenthere, how is control actually capturing that data? Have you known a particular % of full scale that my be incorrect? I'm not to familiar with this control. He did state it was 32 outside. Not knowing the number of total supply diffusers, it just seems very low once we look at the possible number of supplies in the house divided by that five hundred.
Always here
12-07-2011, 09:38 AM #24
12-07-2011, 09:41 AM #25
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
12-07-2011, 05:42 PM #26
The VS motor Carrier uses is a communicating motor(it communicates with the infinity control). They use to use the 2.5 version, but now are using the 3.0 version.
It won't always read the same as a manometer will. but that is mainly from placement of the static probe, from the few that i have checked.
But I wouldn't rely on it only, if you ant to know how much air the system is actually moving.
