Results 1 to 9 of 9
Thread: Number and location of HVAC's
02-21-2006, 10:44 PM #1
- Feb 2006
- 2
My builder of my townhouse is asking us to approve the location of the HVAC. We have 2 levels and a basement and they are requesting to place an HVAC on my 2 levels when my basement already has a "utility" room.
Do I really need an Hvac on each level? Can't an HVAC in the basement serve my whole townhouse? Do these hvac's add to my ultimate utility bill? I would really like to save the space if possible and if it makes sense. My townhouse is small enough as it is.
02-21-2006, 11:17 PM #2
Professional Member*
- Nov 2004
- SW FL
- 5,356
YOUR Comfort
1. No.Originally posted by ejyoung
... 2 levels and a basement and they are requesting to place an HVAC on my 2 levels when my basement already has a "utility" room.
1. Do I really need an Hvac on each level?
2. Can't an HVAC in the basement serve my whole townhouse?
2. Yes, but is an 8'F temperature difference between basement and top level acceptable yo you?
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
02-22-2006, 12:24 AM #3
- Apr 2003
- arizona
- 629
need more info, floor plan and sq footage, there are so many factors... your builder doesnt have an engineer to figure this out ?????????????????
02-22-2006, 03:14 AM #4
- Nov 2004
- SW FL
- 5,356
TWO + = Better
Dave,Originally posted by dave82323
You think it takes an engineer to determine the
__# of units__
that are needed?
It is quite obvious that
TWO systems or
one heatpump + zoning
+ dehumidifier
(essentially TWO Systems for practical purposes)
are needed.
The installation and operation are both enhanced
with a minimum of two systems +
dehumidifier for part load conditions.
One unit should be located in the basement
in accordance with The Owner's request.
Of course, having one unit does NOT save an appreciable, if any, amount of space (or may actually increase the total volume) when one considers the unit sizes versus the added supply air ductwork needed to get from the basement to the second floor plus the returns.Designer Dan
02-22-2006, 07:27 AM #5
- Oct 2005
- 921
Size
What is the sqf of each floor and what is the reason he would like two and not one unit. You have asked an open ended question and have provided little or no info t0 help
02-22-2006, 09:05 AM #6
- Feb 2003
- Huntsville,AL
- 4,125
the conditioned air must get from the unit somehow, and not just by flowing up the stairs-
buy a townhouse in the middle to have others condition the sidewalls! -- providing the construction is good enuf to stop most noise transfer.harvest rainwater,make SHADE,R75/50/30= roof/wall/floor, use HVAC mastic,caulk all wall seams!
02-22-2006, 09:32 PM #7
- Feb 2006
- 2
Thanks everyone for the responses, its only 643 sq. feet per floor. I have 3 bedrooms on the top floor where they have proposed to put the hvac in one of the bedrooms. They proposed another hvac in the living room in the corner...
02-23-2006, 05:19 AM #8
- Nov 2004
- SW FL
- 5,356
Duct Chase
K.I.S.S.Originally posted by ejyoung
..., its only 643 sq. feet per floor. I have 3 bedrooms on the top floor where they have proposed to put the hvac in one of the bedrooms. They proposed another hvac in the living room in the corner...
Locate a ~2.5 unit + dehumidifier + zoning dampers + controls in the basement utility room
with ~18"x18" duct chase (8"x16" Supply & Return air ductS) through the pantry or closet on first floor if the diffusers will be mounted on the floor.
Townhouse will require something like
FOUR 8" diameter (~ 150 CFM each) Supply Air ducts for each of the 643 S.F. floors.
Zoning :
http://www.arzelzoning.com/whatiszoning.html
Dehumidifier:
http://www.energystar.gov/index.cfm?..._dehumidifiers
Designer Dan
02-23-2006, 07:16 AM #9
- Oct 2005
- 921
Living space
Do not give up living space unless you have to. Does he give a good reason for two units and two locations?
