Thread: Need help choosing Heat Pump
02-21-2006, 06:10 PM #1
- Feb 2006
- 2
History: I have a 25 year old carrier air handler that has a relay gone bad and isn't using all the coils. I have a 91 goodman heat pump that has had problems but is working fine now. Weather is fine now so heat pump is having a problem, but weather is changing this weekend. We have had the house 2 years and don't plan to keep it more than 5 more.
I can't seem to find comparisons anywhere. Please Help!
Options in order of price:
York Air Handler Only
Heil Air Handler Only
10 SEER York
10 SEER Payne
13 SEER Heil with R410A
13 SEER York with R410A
10 SEER Bryant - it must be gold plated for as much as they want for this one.
02-21-2006, 06:21 PM #2
You are on borrowed time on that heat pump too. I'd replace all.
If you have very cheap electric rates, the 10 SEER would be your best combo between operating costs and initial cost. If juice rates are higher or you are in an area with lots of cold or hot, then better look the 13 SEER route.
02-21-2006, 06:23 PM #3
- Feb 2006
- 2
I'm in Indiana so no extremes for long periods of time.
Any preferences on York Vs. Payne?
02-21-2006, 06:45 PM #4
- Nov 2001
- 1,874
Yeah, Lennox
If you try to fail, and succeed.
Which have you done ?
02-21-2006, 08:07 PM #5
What electric company? Cincergy & IPL have very cheap rates. You won't find payback in 5 years for 13 SEER!
Payne and builder York are about identical, the York Stellar is better built and would be my choice in the 2 brands. 5 year parts & labor wise with either!
02-22-2006, 06:41 AM #6
Professional Member*
- Nov 2004
- SW FL
- 5,273
U like ..
PreferencesOriginally posted by dcnz
Indiana. Any preferences on York Vs. Payne?
1. Trane
2. Lennox
3. Climate Master
4. York
5. Bryant
6. Armstrong
7. ...
8. ...
9. ...
10. ...
11. ...
12. ...
13. PaIn
14. Goodman
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
