Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 79 to 91 of 139
  1. #79
    Quote Originally Posted by hvac wiz 79
    from where? i want to make sure i get those & not leftover from the early ones lol
    Straight from Digi-cool
  2. #80
    las vegas
    ok doug
    now it is time for you to put all the paets in a bag & start marketing the diy
    a cools with no instructions & a 900 # ... the only problem is you will run out of hair pretty quick. this product is too solid to be playing with but like every otherpiece of
    equipment it does have a weak spot. that will be overcome when you get the wireless
    op & ronnpng. but then another snake will rear its ugly head.
    supposed to be meeting a fellow this pm thet
    markets specialty wire & connectors & orings so maybe he has some rings
    that may work with your shuttle valve problem.
  3. #81
    how long did it take to get from Canada to somewhere between raising hell & amazing Grace? .. that's the last question . . i think lol
  4. #82
    Quote Originally Posted by hvac wiz 79 View Post
    Honestly, only a couple of days, from Canada to Western PA
  5. #83
    Jan 2001
    whats everybodys opinion of the new velco probes-price,longevity
  6. #84
    just got my clamps. after looking at these i must say i did a pretty damn good job at the one i made . I'm debating on modifying it to work on the ak w/ the reg connection or the 1/8 jack .. decisions decisions
  7. #85
    My boss bought an AK and wound up building his own clamps and installing ballast quick connects in the lines to switch them.
  8. #86
    you take pics? .. im not sure i know what a ballast quick connect is without seeing it. I'm gonna stick to 1/8 jack for now in case a clamp fails, i can use the cooper .. or if it's a tight fit i can use the cooper.
  9. #87
    here's the latest & I'm hoping this lasts. i have an extra probe from the original set that came with the ak. if one fails i can use it w/ the clamp. i used the color heat shrink to make life easy when plugging in. only thing i don't like is the Velcro I'm using but it's temporary. the Velcro it came with tore apart when i removed it from both
  11. #89
    Jan 2001
    is that the original wire that goes into the ak900 plug. looks good
  12. #90
    Quote Originally Posted by hvac17011 View Post
    thanks. yea. tried to beef up the part where it comes out of the connector with heat shrink. seems tough enough.
  13. #91
    ontario
    What kind of clamps are those. What model number is it. Where can I get it.
