Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 40 to 52 of 139
  1. #40
    In the work truck
    I meant the standard DC sensors. Isn't that what you were using and saying they were inaccurate?
    I've found no reason to question these sensors when tightly connected to the line and insulated well.
    I was referring to the Digicool pipe clamp's they were over a hundred when I bought the 1250's.. For some reason when I upgraded to the pipe clamps I did not get the standard sensors. It would be nice to try them and see how they work..
    Gotta have the right tool for the job!
    Where is all the stuff MADE IN THE USA?
    "Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
  2. #41
    In the work truck
    Quote Originally Posted by hvac wiz 79 View Post
    i loved the Cooper red clamp but they would only last a season. for 120 a pop(i think that's what they were) i had enough after a few. i have quite a few of those pipe straps that come with the Cooper boxes but never cared for them so i was going to try them in my test modification ..
    What failed on the Red Clamps? Im about a year in with mine and so far so good. I really like them as well as the strap pipe sensors...
    I am still going to pick up another set to use with the 1250's and see how that works.. From the get go when I bought the Dc's I never used the clamps because the temp reading was off. I brought in the cooper box and the DC's.
    Now I would really like to see an accurate reading on the 1250, thus the reason for the modification...
    It will be interesting to see what comes about with this new ak900 style thermistor..
  3. #42
    Oct 2008
    Nashville ,TN
    I have my ak mod with the Cooper straps , I haven't noticed any temperature problems.
  4. #43
    Jun 2006
    Torrance, Ca
    Quote Originally Posted by Thomasg View Post
    Have you bothered to check? I thought my micron gauges were fine until I bothered to check them against one another.
    Dan
    If you don't notice, I'm doing my job.
  5. #44
    Oct 2008
    Nashville ,TN
    Yes in ice water and my cooper box.
  6. #45
    Aug 2008
    Cincinnati, oh
    do you have pics of what you did. I just got my AK900 and I am wanting a nonvelcro option
  7. #46
    Quote Originally Posted by jpsmith1cm
    Here's a little trick that I've come up with to protect the sensors.
    Take the sensor and carefully wrap it up about the width of your palm and close the velcro around it.
    Now, wrap a piece of insulation a bit longer than it is around it and wrap a mille-tie around that. Radio Shack has them around here.
    Quote Originally Posted by fheatair
    Try the link in the post quoted above yours.
    They work great.
  8. #47
    Oct 2008
    Nashville ,TN
    http://hvac-talk.com/vbb/showthread....1019051&page=2
    Jp idea is pretty good also if you dont want to take the chance of messing your new sensors up. I did mod only because I pulled my sensor wire out of the sensor going up a ladder. I keep them in a small bag that slides down the hanger now works great.
  9. #48
    x2 on keeping them in a small bag connected to the manifold. i keep a few millie ties in there as well.
  10. #49
    i did the mod the other night & am able to use my cooper straps now ... didnt really care for the strap type probes before but thats because i was spoiled using clamp on. it works & looks great. im going to take 1 of the 2 probes that came with the ak900 & modify an old testo clamp a friend of mine threw away after the connection pins broke .... id share pics but anyone who has read this thread has seen the idea already
  11. #50
    I've got an idea or two for an interesting Digi-cool sensor mod.
    I've got materials on the way right now for it.
    I'll take pics as I do it for you all
  12. #51
    i did the clamp set up .. here's the pics. it came out decent i used some scrap wire from a digital temp control i had to shorten the sensor length on & the testo clamp. the part i don't like is I'm only getting 33 on it no matter how much i stir up the crushed ice/water mix compared to the 32 on my Cooper strap. how bad could that 1 mess me up or is it tolerable? its irking me
  13. #52
    OK, I finally got the parts ordered, the time set aside and grew the B***S to start remodeling a DRSA.
    Here was the plan. Purchase a set of dual scissor clamps and some materials from Digi-key.
    Chop the 4 pin connector off of the dual scissors and install individual plugs to match the original 1200 connector.
    Rip the 4 pin connector out of the AK and install 2 plugs matching the 1200.
    This gives me the advantage of using a single sensor if I want a single and dual sensors when I need it.
    I've also got the ability to use clamps or simple probe sensors as needed or wanted for the job at hand.
