    Aug 2011
    changeing compressor
    hey everyone thought I would ask if anyone has changed hermetic compressor to a scroll r22 walkin only have a a/c scroll r22 available today have accumlator and can rewire no problem it would be a cr18 to a zr18
    Aug 2011
    it worked great btu's were close in high temp applcation so I thought it would be fine a little rewiring and repiping customer satisfied scroll very quite compared to old cr18 compressor
    Dec 2011
    Refrigeration training
    Hello, I worked for a refrigeration company for about a year years ago and would like to get back into it. Does anyone have any ideas where i could get good training in the Austin, Texas area?
    Southeastern Pa
    Oasis, you should start your own thread. Thanks.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    May 2003
    Utah
    The compressor's function is simply to convert a low pressure vapor into a high pressure vapor. As long as the compressor capacity is correct for your application, it doesn't matter how the compressor accomplishes its task (pistons, scroll, rotary, screw, etc)
    The real determining factor will probably be how much extra work do you want to do to install a compressor that has different mounting, piping and electrical connections compared to the OEM installed compressor.
