Results 1 to 12 of 12
    Delaware
    Who do you think makes this unit
    Top has a crack by condensing fan, homeowner wants it repaired not replaced.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	228462   Click image for larger version.
ID:	228472   Click image for larger version.
    Always here
    Nov 2007
    Looks like an old Goodman unit. Don't think you'll find a new cover but you can probably weld it.
    Jan 2006
    Northwest Missouri
    looks like a goodman to me too.
    Float'N Vally, MS
    Quote Originally Posted by eliteair View Post
    No need to replace. Wait a little bit and the problem will take care of itself.
    Life is too short, Behappy!
    TFMM
    Virginia
    I fixed one with a piece of sheet metal and some washers when I replaced the motor,although it was in need of replacement I don't have a problem repairing it. it's a janitrol/ goodman
    Oct 2011
    Arkansas
    I'ts a Goodman. Welded up one last winter.
    Oct 2005
    sacramento calif.
    you can bolt a piece of angle metal to span across the grill & out on to good metal picking up both the bolt at the crack and the one opposite. looks like you need through bolts out of an old motor to replace those rusted up ones though.
    i was born under a wandrin star.
    Dec 2001
    Ocean Pines, MD
    Are those cracks a registered GM trademark?
    Delaware
    Thanks everyone. I'll have to come up with a solution. I think the angle iron on top is a good idea. I may weld the crack shut, this would stop vibration that may contribute to elongating that weak spot. (kinda like a windshield crack)
    Always here
    NC
    Make sure the HO is aware that the repair is not warrantied. If/when that thing cames apart they might be looking for someone to make the proper repairs- free of charge.
    Delaware
    yep. No warranty. I removed the whole top, covered the unit, bringing to a Buddy's house to run a bead on
    Always here
    Athens, Ohio
    I can't tell from the picture - has the condensing fan motor been replaced with one that is heavier than the original? If so, that has contributed to the crack. The metal has trouble supporting the OEM motor, and a heavier one just exacerbates the situation.
    (I got to use that cool word in the last sentence!)
