Results 14 to 26 of 33
Thread: strange system
12-04-2011, 08:16 AM #14
No, The txv is wide open, it's not restricted or low on charge which is what would cause lower pressures. The issue at hand with the info given seems to be refrigeant is boilng off too soon in the evap, because not enough is entering, which is what's causing the 25degree evap SH Your goal should be somewhere between 6-10.
Local 597 Service Fitter
Metal Trade Journeyman
PAY ME NOW OR PAY ME LATER
It was working when I left...
WWFD
12-04-2011, 05:01 PM #15
- Jun 2003
- 3,633
A have a restaraunt that has dual condensers on their walk in. Water valve is set above the normal condensing pressure so water is only used if the kitchen is extremely hot or the condenser gets greased up. Works extremely well. Unit is over 30 years old and has only broken down once.
12-04-2011, 06:57 PM #16
- Jul 2009
- Northern area between Alantic and Pacific
- 106
12-04-2011, 07:22 PM #17
- Jun 2003
- 3,633
Sounds about right, but i'm not sure, since I didn't touch it. I know on most days no water flows down the drain, but when the kitchen starts getting over 90 degrees (probably 110 up by the condenser at the ceiling) water starts to flow.
Last year the restaurant got shut down in a surprise health inspection on the hottest day of the year. Had to trash the food in 5 prep tables, 2 reach-ins and 2 walk-ins. They called me out right away. Found the temp at 110 in the kitchen, probably 120-130 at the ceiling. Voltage was 104 at the outlets and a transformer on the utility pole was spewing oil from a relief vent. Most compressors in the place were off on overload, but old trusty was purring away holding 34 degrees while employees were stuffing all the surviving food into it.
Restaurant owner wanted to know if it was possible to equip his other equipment with supplemental water cooling.
12-04-2011, 08:07 PM #18
- Sep 2011
- Augusta, ME
- 69
supplemental water cooling does seem like a clever idea, I can think of quite a few businesses in my area that could really use this method but it might be more cost effective to just relocate condensing unit outdoors if possible
12-04-2011, 08:43 PM #19
12-05-2011, 12:44 AM #20
Sounds really cool but it sounds like they have had to many messing with it i have seen something like this to switch in summer and winter ended up making them all remotes and took out the water side all together like to see some pics of this setup
12-05-2011, 08:53 AM #21
- Jul 2009
- 106
Thanks,icemeiste. Those two condensers connected in series and the water cooled upstream of the air cooled.I think the water cooled act like desk Ernest device then the air cooled cond act like condensing and sub cool . The regulator doesn't have mark on it and I have no clue what pressure would open the valve. So I thought it might use the outlet temp for R and water to adjust the pressure regulator. Am I wrong? Plesase give the detail how to do it,thanks.
12-05-2011, 02:06 PM #22
- Jul 2009
- 106
The water cooled cond act like de-superheat device and the air cool cond doing condense and sub cool. Sorry for the typing mistake.
12-05-2011, 05:31 PM #23
12-05-2011, 05:48 PM #24
- Jan 2010
- 4,410
12-05-2011, 06:08 PM #25
- Jul 2009
- 106
12-05-2011, 06:54 PM #26
