+ Reply to Thread
Results 1 to 2 of 2
Thread: UV lights
    Jan 2006
    Will U.V. lights break down armorflex insulation? I relined my package H.P. evap section after a water leak last year with it (had to tear out factory insulation) I've also heard that the light affects the plastic drain pans, that true? Thanks.
    Apr 2003
    the Great Pacific Northwest
    From Field UVAir brochure
    Q. What effects will UV-C rays have on plastics such as coil
    pans & flex duct?
    A. If the plastic is not UV resistant, UV-C can cause a breakdown
    of the material over time. Based on lab tests, positioning the
    lamp 30 inches or more away from plastic surfaces will
    eliminate any measurable breakdown of plastic material.
    armaflex will have problems also.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
