Results 1 to 7 of 7
    Nov 2011
    Any Generic (non OEM) True Compressors out there?
    Ive always used OEM parts for everything, but for my personal use, I am curious, does anyone make a cheaper generic compressor for True's? Ive made calls around and all my vendors only use OEM stuff.
    Brandon
    ART
    Jul 2000
    Cuenca, Azuay, EC
    "Most" True compressors are essentially the same as the ones available from the wholesalers' stock...but there are sometimes minor changes in the Bill Of Material (BOM) numbers which may require a little "field modification" to make the standard ones fit.
    Apr 2003
    Maple Grove, MN
    Any good refrigeration wholesaler should be able to help you cross it over and give you some different options if you have the model number from what ever is in there now.
    Mar 2002
    fort walton beach fl.
    check out the attachment.
    http://acfwb.com/
    "The best preparation for good work tomorrow is to do good work today"
    Nov 2011
    Thanks for the link murphy, lots of choices but none that really match up to whats in it =/
    The stock compressor is a Copeland KAM2-0075-IAA
    3/4 Hp 120v
    Mar 2002
    Whats wrong with the compressor.
    http://acfwb.com/
    Nov 2011
    If you are going through all that work replacing the compressor do you really want to take a chance on something that may be inferior?
