Results 1 to 13 of 13
    Apr 2005
    How do you determine the safe liquid level in your recovery cylinders? I have been talking to techs over the years and I always get different answers. I know the correct way is to calculate with a bunch of formulas from water cap. and ratios of saturated temps of liquid. I am talking real world. For example.. If you are using a 125# cylinder, I have been told to fill to net weight from 100# or 125#.
    70% of container capacity
    125 x .7 = 87.5
    What refergerant is it?
    if you have a bottle to hold 30 pound r-12 , how many pounds of r-22 will it safely hold?
    Apr 2005
    Answer 26.8 #??
    Why are you using 70%? Is that just a safe percentage for all refrigerants? I typically use 80%. I use alot of different refrigerants. 22,12,502,123,11, ect..
    What most people forget is the capacity of the cyclinder is at 70F. If you fill it 80% and it sits in your truck on a 95F day it could go hydrostatic. Look at your pt chart for the most reasonable temp the cyclinder will see but in my opion 80% is pushing the limits, if it will see unusually high temps.
    refrigeration workers of Ontario
    Apr 2005
    For example 125# recovery cylinder at ambient density of R22 at 130* is 66.312.
    Take that factor 66.312 divided by water density 62.4 = 1.06. If the WC of a 125 is 121, mutiply 121 and 1.06= 128.26.
    The tank has a total liquid capacity of r22 of 128.26 @ 130*. 80% is 102.6 net refrigerant.
    Quick method is 125 tank multiplied by .8 =100 net refrigerant
    Apr 2005
    Australia : Queensland
    80%
    formula is
    water content x filling ratio + tare weight
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
    Jan 2001
    I usually fill them to where I feel comfortable carrying them....rest goes into that big recovery cylinder in the sky.....
    Sep 2001
    Rochester, New York
    I guess I never much thought about that. Every time I exchange or purchase a new recovery bottle, I weigh it empty and write it on the cylinder. Regardless of which refrigerant I am recovering, when I get to, or close to the “rated” weight, I stop adding to that tank. I think the 30 pounders weigh around 16 pounds empty. I would only fill that tank to about 45 pounds or so. I know about the rule of 80%, but isn’t that already built into the volume of the tank? Interesting.
    Nov 2005
    Recovery Cylinders
    Each and EVERY bottle is stamped with capacity in WC.
    The Simple fact of LAW states 80% of WC.
    You can go less, but not more.
    There is actually no such thing as a 30, 50, or 125 lb.
    recovery cylinder.
    The capacity of any recovery cylinder is stamped and
    Approved only for what it was certified at.
    This is not a place for Rule of Thumb.
    If DOT, or any other Department of Regulation
    checks you out, you had better be legal, or they
    will write you a little Rule of Thumb ticket that
    will hurt your Ego, and your hip pocket.
    Regards.........
    Apr 2005
    Re: Recovery Cylinders
    [QUOTE]Originally posted by gonefishing
    [B]
    recovery cylinder.
    You are still cutting short the capacity of you cylinder if you are not converting your WC to the correct refrigeration density.
    If a 125 recovery tank has a WC of 121, you could fill to a net of 102.6 of R22 using the density factor of 1.06.
    If you just use WC of 121 @ 80% will be 94 pounds.
    [Edited by ej45 on 02-18-2006 at 09:42 PM]
    EPA regulations state that you are not to fill any cylinder above 80% of its rated capacity.
    I'm with the others on this, while your research into refrigerant densities at given P/T's is arguable, the rule of the law is 80% W.C. It could very well have something to do with air and non-condensibles, or excess oil from the system, but you cannot go over the afore mentioned amount.
    Apr 2005
    I am still filling to 80%. Refrigerant has a different density than water. I am using the method from ACCA manual.
