Results 1 to 13 of 15
    Jul 2011
    eccentric sheave ?
    what its use for and where most likely to find eccentric sheave in this industry? is there a tricks about proper way to remove it?
    any info will be appreciated.
    have never seen eccentic sheave in the field
    I'd really like to see one spinning at high rate of speed
    Dec 2008
    Dixiana, AL
    I think they're used for testing the life-cycle of vibration isolators..........
    Nov 2011
    British Columbia
    ^^funny^^
    Maybe you mean split-taper sheaves with a concentric bore? Like this:
    http://www.emerson-ept.com/eptroot/p...itTaperShv.asp
    Jul 2001
    Southern NJ
    Quote Originally Posted by RuralSpaceman View Post
    ^^funny^^
    If so:
    you remove the 3 bolts from the face off the sheave and put them into the three empty holes. Tightening these 3 bolts evenly presses the tapered hub out of the sheave and the thing just falls apart.
    Ryan
    Maintenance Guy
    naysayer, skeptic, conspiracy theorist
    New Mexico
    An eccentric sheave is just what it says, out of round. When the eccentric hub is tightened it secures the sheave. It's to be tightened with a drift and hammer in the direction of rotation. It's usually easier to remove these sheaves than some other types.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Oct 2001
    I have never heard about eccentric sheaves. I know eccentric sleeves used in pillow block bearings.
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by hvacker View Post
    In 35 years, I've never seen nor heard of an eccentric sheave. Neither have I seen an eccentric locking collar on a sheave. The only thing that comes close to either one in this discussion is an eccentric locking collar on a bearing sleeve. Maybe I'll stand corrected before this thread peters out......
    Somewhere in the world.
    Quote Originally Posted by klove View Post
    I would have to agree with this statement only thing that I have ever seen is a bearing locking collar nothing else.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    What you are refering to is a tappered hub as the bolts on the hub are tighten they pull the sheeve closer to the hub until its tight same goes for removal using the bolts to spread it apart.
    Jan 2010
    Found them on pillow blocks of make-up air units. Set screws are more common.
    New Mexico
    I don't know if any one manufactures an eccentric sheave or not.
    FYP's ? was what it was.
    It's a locking device.
    Could it work on a belt drive? It could probably grip as well as set screws.
    Like others have said, most common use of an eccentric is as a locking collar.
    SMW Lu49
    Jul 2011
    Hi Hvacker,
    thanks for info,you said tightened in the direction of rotation.
    so when removing it does it rotate to the opposite of the rotation?
    may be i will come across a job for this one day
    do you have any web link to it?
    I saw a two of eccentric sheave in our HVAC parts section and no one here recall what it was for. no brand or anything like that and the manual missing some section of how to install and remove it.
    its about 4'' diameter eccentric and flat around it with collar. its look like belt tensioner for auto engine.
    thanks
