Results 1 to 13 of 14
Thread: Goodman
    Oct 2005
    Confused
    Any thoughts on how Goodman products are doing these days, as in reliability and performance?? I know installation is key, but if installed correctly, are they any good?? thanks
    Apr 2004
    Very reliable. We don't have too many problems. Installed correctly is the key phrase.
    Jan 2006
    Reliable,good warranty. I did replace compressor and reversing valve in 2 year old unit due to compressor wires grounding out in bottom of cabinent against liquid line. I have also seen Trane 2 year old trane unit ground out its crankcase heater. My point being from so called "low end to high end" units all are subject to unforseen circumstances.Bottom line I installed goodman heatpump in my own home.No problems so far (1year)but I also know system is tight and was installed correctly.
    Nov 2000
    Eastern PA
    Goodman...have been...vewy good....to me!
    This would be a great time to close this thread
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Sorry Robo, gotta let the Goodman bashers have their fun
    Seems to be an epidemic of wires rubbing through and copper tubing rubbing through these days. Worst is these Rheem cubes, seems like we're always losing something on them.
    Florida's space coast
    We install a fair amount of Goodman equiptment.
    I havent noticed more problems with them than any other brand.
    When a problem does occur they always honor the terms of the warranty.
    We've been doing so much,for so long,with so little, that now we can do almost anything, with nothing at all.
    Ok Robo,
    Let me start:
    Goodman is Junk...
    Lennox is a lemon...
    Payne is a pain in the a$$..
    Bryant is garbage...
    Carrier is $hit...
    Nordyne is recycled junk..
    Trane is in the toilet..
    etc.. You get the point!!
    This is if installed by DIY or a hack..
    A professional installation,, any brand can work to its abilities.. Each brand has higher tier units and builders models and some have inovations that other don't...
    My question would be did my hvac Contractor:
    1.) Load calculation
    2.) Verify ductwork is proper for system
    3.) Go over any problems you currently have,,, i.e. Some rooms cold/others hot..
    4.) Did he instill impress that he will do the job correctly..
    5.) Did he concentrate on providing a complete job proposal for all your concerns or did he just focus on being the cheapest or offered to beat any other deals..
    6.) etc... you get the point..
    A Great contractor is the most important,, then go with the best set up that contractor is offering..
    Goodluck
    J
    Nov 2000
    Eastern PA
    Rheem has a cube unit again?
    Advanced; you are correct, they are all junk. If not, we would all be on unemployement
    Jan 2002
    Ft.Worth,Tx
    Angry
    XXXXXXXXXXXXXXXXXXX
    Everyone please, please remember
    Flaming or Bashing = 3 Days R&R
    Continued Flaming or Bashing = Banning
    You will not be notified of your removal
    Thanks!
    [Edited by senior tech on 02-18-2006 at 10:23 AM]
    'Life begins with the journey each day'
    Technically the cubes aren't sold under the Rheem name. Corsaire, Zephyr, WeatherKing, Duroguard, ThermalZone...
    The A/C units are great, the pumps have been a nightmare.
    Nov 2000
    Eastern PA
    OK, I knew this. I agree about the heat pumps. When I was a Rheem/Ruud rep inspecting heat pumps during a particularly long spell of ice storms I could pretty much diagnose those cubes while pulling into the driveway.
    Nov 2000
    Eastern PA
    Originally posted by aircooled53
    XXXXXXXXXXXXXXX
    It is true that the suction pressures on Goodman equipment is superior to that of other brands. Good of you to point out yet another quality feature aircooled
    [Edited by senior tech on 02-18-2006 at 10:25 AM]
    chicago suburbs
    got a 2.5 tonner sitting just like this in my garage that i'm gonna install on a townhouse i own in the spring. she's got a little dent in the side but was priced right.
    FILL OUT YOUR PROFILE!!
