Results 1 to 13 of 32
    Jan 2011
    Alabamer
    Question Do I really need a 20,000 ohm, 5 watt resister to de-energize a capacitor?
    This is probably a question you electricity-specialists will be able to answer best: I am curious to know whether I can use a fixed resister, one that is cheaper than those 20,000 ohm 5 watt resistors that sell for like $5 each:
    http://www.amazon.com/KOA-Speer-Thru...=2X4KV41DYHD7C
    Can I really use a different resistor that can accomplish the same task safely, namely one with a higher resistance and lower wattage, or should I not press my luck? lol
    Jun 2011
    Screwdriver?
    Jan 2011
    Alabamer
    Wink
    Quote Originally Posted by Redwood650 View Post
    Screwdriver?
    I thought doing that would ruin the screwdriver AND the capacitor? lol
    Jun 2011
    How big are the capacitors? I work residential and I just use a screwdriver. I've yet to see anything happen using a screwdriver.
    Jan 2011
    Alabamer
    Wink
    Really? I'm new to the field. I was just curious to know if I could use a diff. standard of resistors just in case (I know, I'm cheap.) If I recall correctly, it was these dudes told me it was a bad idea to use a screwdriver anyway (lol):
    http://books.google.com/books?id=eS_...gbs_navlinks_s
    So if the capacitors are big, then I probably should use a 20k ohm resistor?
    Jun 2011
    Quote Originally Posted by Epic_Win View Post
    Im new as well. I was told by my teachers at my trade school that the "proper" way is to use the resistor. However, the majority uses screwdrives. So thats what I do and I have no issues. Lets see what others use
    Chester County PA
    Think about what a resistor is and does. It's just resistance.
    Do you know why a start capacitor comes with a "bleed resistor" from the factory? Do you know why you should be extra careful if you come across a start capacitor that someone before you cut out the bleed resistor?
    You can discharge a capacitor by crossing up the two leads. A resistor will allow the energy to flow slower versus using a screwdriver. Slower is better when dealing with energy.
    I have never seen a Run Cap hold a charge after the circuit has been de-energized. Rest assured I still respect them and I'm treat them like a loaded gun.
    ~smoke~
    "That motor's done, he let the factory smoke charge out!"
    screwdriver, wire strippers, needle nose, ...whatever is handy & insulated
    South Carolina
    I would use a 4 watt resistor that is 20,001 ohms !!!!!!!! they are cheaper
    It is what it is unless I say differently !!!!
    Nov 2011
    Central Va.
    My meter has a setting for checking microfarads, I use that. Usually you will test the capacitor (unless blown) anyway.
    Apr 2001
    When I was green, I used a radio shack resistor, like the book says. Now, I use a screwdriver. I discharge every run cap, since I check them usually. The only one I have had arc on me was the one with power on!
    I never had a start cap arc, either, but most have the resistor built in.
    Jason
    Aug 2008
    Nebraska
    Anymore I don't even short them together. I just grab them and take the wires off. The only time I get hit by one is when I forget to turn off the power to the unit.
    Jul 2010
    nebraska
    AC's... I pull the disconnect and push in the contactor. Little 5-25 mfd on a psc blower motor gets shorted,after killing the power. My first meter had a fuse that would blow if the caps were not shorted before testing so I got in the habit a long time ago.
