    Apr 2008
    Hussman cond unit wiring diagram
    Im working on an old Hussman condernser unit. Vertical blow style no model or serial number. Im looking for the wiring diagrams . If anyone has any it would be great. Or if you have a model number . thanks
    Jul 2000
    Treasure Coast/Florida
    You're not giving us much to go on here.
    Is this a "condensing unit" with a compressor, receiver, etc. or is it an "air-cooled condenser" with just a coil and fan(s)? There's a big difference.
    Pictures would help, but I think you need a few more posts before you can post pics.
    Apr 2008
    It's a whole condenser. Compressor, receiver, contactor, defrost control , I'd say it's probably 20-25 years old
    Jul 2000
    Quote Originally Posted by air-row View Post
    Then in proper Refrigeration terminology, that would be a "condensing unit".
    The only Hussmann condensing units with vertical air discharge that I recall would be in the 10+ horsepower range and up. Essentially, those are skids with a compressor package mounted at the header end of the condenser.
    For starters, what is the compressor model number? That would help narrow this down a bit. Also, what's the application and refrigerant? HT, MT or LT?
    If it's 20-25 years old, I could have info on it. That's my era.
    Apr 2008
    It's a walk in cooler application. 38 degrees. R22. Tecumse recip hermetic compressor. No nameplates on unit or compressor.
    Jul 2000
    This may help:
    http://www.hussmann.com/Discontinued...%20HIRU_im.pdf
    The typical electrical schematics near the end are fairly generic, so whatever it is you're looking for should be in there someplace.
