Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 50
Thread: L1 and L2!!
  1. #27
    Nov 2011
    texas
    Quote Originally Posted by snewman24 View Post
    If we're still talking about the circuit below, then for purposes of how the motor circuit works there isn't any difference. That circuit would usually be a 240V single phase circuit, where "line" is L1 & the other "line" is L2 and both are "hots" and there is no neutral.
    If the compressor were rate for 120V instead, one "line" would be L1, and the other "line" would be Neutral, "N", because it's connected to the center tap at the transformer, but for all practical purposes nothing has changed except the voltage.
    Don't get hung up on the term "neutral". It's a power wire just like L1 is. It brings power into the run cap just like L1 does. Power comes in thru L1 and leaves thru N, and it also comes in on N and leaves thru L1, alternating back and forth.
    Thank you very much. I never really had a thought l1 and l2 had a relevant difference in voltage or function of each other, but I needed to ask. But, y'all have pretty much cleared up the differences between 'hot' and 'neutral'.
  2. #28
    Nov 2011
    texas
    Because of that small lesson alone I'm able to read pretty much any circuit in my book now.
  3. #29
    Southeastern Pa
    Great!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  4. #30
    Feb 2017
    No
    Quote Originally Posted by timebuilder View Post
    I'm not sure what you have been told, but throw away any ideas about one side of a circuit having one function or another, versus the other side off the circuit.
    The ENTIRE circuit has current movement when energized, and the ENTIRE circuit loses current movement when de-energized.
    If you believe that, design your metallic lamp with the power switch on L1 and then touch your lamp. You will learn that only part of your circuit has current... o.O
  5. #31
    Feb 2017
    Switches always go on the neutral side.
  6. #32
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by wickedchild View Post
    huh, wut?
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Glennac - Failed my biology test today: They asked, "What is commonly found in cells?" Apparently "BL*** people" wasn't the correct answer.
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
  7. #33
    Feb 2017
    nice reply... yes what.
  8. #34
    Feb 2017
    lol sorry had a brain fart. hot side! hot side!
  9. #35
    Feb 2017
    I said L1 first! ...
  10. #36
    Mar 2013
    nice save
  11. #37
    Feb 2017
    Strange that I can't delete or edit posts?
  12. #38
    Mar 2013
    because you're a guest
  13. #39
    Feb 2017
    Well feel free to delete all of this. It isn't very helpful. Remember kids, switches and fuses go on L1, the hot side.
