    Apr 2005
    Kingston Ontario Canada
    I read in another post that on Carrier or Bryant heat pumps that only Parker drier made for R-410A are the only approved drier that should be used. When I had the TXV changed on my Carrier 38YZA late last summer the company I had work on my heat pump used the following liquid line drier.....
    Reversible
    CATCH ALL
    For Heat pump systems/HPC 103-S
    For use with R12 R134A R22 R404A R407C R410A R500 R502 R507
    Sporlan Valve Co.
    Washington, MO
    MRP 680 PSIG ( 498 KPA)
    Do you guy's know anything about this type of liquid line drier? Am I ok with this, or is it going to compromise my heat pump?
    Thanks in advance for your advice!
    Thorton
    [Edited by thorton on 02-15-2006 at 02:34 PM]
    Ask Carrier? I don't know why it would be a problem, it's rated for 410a and heat pump. Parker bought Sporlan, just an FYI.
    Mother is the name for God on the lips and hearts of all children. - Eric Draven
    Site Rulez!
    Hell Hole Swamp
    Carrier wants the molecular sieve type dissicant used, like in the Parker, I dont think the Sporlan uses it, still better than not using one at all, I wouldnt loose any sleep over it.
    Apr 2002
    Dallas, TX
    That's a fact on both counts. Pre-the acquisition, Carrier awarded Sporlan the TEV business and Parker the filter-drier business for their R-410A units They probably felt it wise to split the business. Funny how some things turn out
    Apr 2005
    Australia : Queensland
    good drier just a little bit less expensive than a danfoss.
    you will be ok they are very popular.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
    Hawaii
    it's fine
