Results 14 to 26 of 27
    Sep 2009
    S.C.
    Lightbulb
    Quote Originally Posted by Pascone10 View Post
    I always stuck the long screwdriver to my ear. It works for me..
    Me too.
    Years ago I had one of the stethoscopes with the 12" rod sticking out the end. Trying to isolate a noise on a running engine I went for the Water pump and got the stethoscope rod hit with the fan blade! It about Busted my ear drums! I've also used a piece of tubing, it works as good as a long screw driver.
    JP you have a SeeSnake?
    Yes, I know I Shouldn't But I Just Can't Help Myself...
    butler pa
    broomstick works also
    Quote Originally Posted by Home&Marine View Post
    Me too.
    Yep. SeeSnake is a cool tool. The new, smaller camera head isn't all that great. I preferred the larger head. It gave a better image.
    I've tried the screwdriver to the ear trick, too. It's good, but I never carry a long screwdriver with me.
    Oct 2006
    Quote Originally Posted by rayr View Post
    I have one that I use to check if my helper has a heartbeat.
    Every morning ?
    I use one, JP. It works pretty good and comes in handy on lots of stuff. Once you get over the other guys you work with cracking jokes when they see you pull it out, it can be a nifty troubleshooting tool that sets you apart from the pack in the customer's eyes.
    I also have a monster 12" flathead screwdriver/prybar/persuader that works just fine on big bearings. It's just big enough to fit in the LC, so it goes everywhere I go.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    Apr 2002
    Omaha, NE
    : I've also used a piece of tubing, it works as good as a long screw driver.
    Exactly...my favorite "stethoscope" is a clean length of rubber heater hose.It works great. It's extremely directional if you're trying to troubleshoot and isolate a "bad" sound or noise, if it contacts rotating parts it's not shoved into your ear, and if it gets tangled in rotating parts it will get sacrificed, and not damaged the rotating parts. Sometimes a standard mechanic's stethoscope is required if you are probing metal to listen to, and isolate bearing noise, or verifying fuel injectors firing on a vehicle, etc.
    Dec 2010
    Fresno, Ca
    I have been looking for one too, I was wondering If you could be helpful in findings leaks in a system.
    Dec 2010
    Fresno, Ca
    It*
    Dec 2012
    columbus, OH
    Quote Originally Posted by ricky24 View Post
    our extern instructor has found leaks with a condensate tube to his ear.
    Nov 2011
    East Side
    I bought the HF one for kicks.....had to use my tube bender to put more of a bend in the ear tubes, and sand the mold ridge off the rubber pieces, to make it more comfortable. It actually works pretty good. I use it to listen to blower bearings, compressor oil pumps, bearings and heads, etc. Not something you'll use all the time, but for the cheap investment, it's worth having on the truck.
    Jun 2008
    In the Boondocks near Marion, IN
    A stethoscope can come in handy, but you will never know the difference between a high dollar Snap-On vs. a Harbor Freight. Chances are that you won't use one much....
    If you haven't already guessed, I'm a gadget guy.
    Always looking for the next gadget or doodad to make my life easier and to help me to make a better, faster and more accurate diagnosis.
    With that in mind, does anyone use one of these?
    Harbor Freight has both a standard one and an electronic version.
    Any input?
    Or are they just a waste?
    Yeah, it's called a screwdriver, and laying your ear against the handle
    From a common sense guy
    Atlanta GA area
    Used to be in auto mechanics (and aircraft maintenance). Bought a Snap-on one and used it more in aircraft. It is in the van... however it does not come out much. Resi work is easy to diagnose... biggest issue is getting the HO to come off a the bucks for a new system they NEED...
    GA-HVAC-Tech
