Results 1 to 8 of 8
    Nov 2011
    Allentown, PA
    Trane RTU 2-Stage Gas Unit
    Can the Trane YCD102 rooftop unit be configured to only operate on low heat or 1st stage. Has anyone had success doing this ??
    Apr 2008
    Why would you want to do this?
    Nov 2011
    Allentown, PA
    The unit is not old enough to replace with a lower heat unit, (which is all the customer needs per their heating requirements). And it will reduce their operating costs for gas.
    Mount Airy, MD
    yes and yes, but not for those reasons.
    This can only go so far here in the open sections of the site. I would like to suggest getting your post count up, apply for Pro and get the details on the other side of the fence
    Deleted your duplicate thread on this. please don't make duplicate threads, thank you.
    Sep 2006
    Ohio
    If the unit is controlled by Trane Tracer, I know you can disable the 2nd stage heat on the front end.
    Nov 2011
    Allentown, PA
    Thanks Hands !!
    Dec 2011
    Pequannock, NJ
    If it's a 2 stage unit, can't you just disconnect Y2? That way it should never call for the second stage.
