Results 14 to 23 of 23
11-26-2011, 05:41 PM #14
- Nov 2011
- 21
11-26-2011, 05:48 PM #15
11-26-2011, 06:05 PM #16
I'm sure I am not the only one that remembers chillers that ran in a vacuum. Probably still some out there.
If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
11-26-2011, 06:44 PM #17
11-26-2011, 07:59 PM #18
Yep.
Low pressure equipment is still out there.
That wasn't quite what I was referring to, though.
I've got more than a couple of pieces of equipment running between 1 and 10# suction pressure and I consider that to be quite normal.
R-12 low temp and R-22 low temp have to run very low suction pressures in order to hold temp.
11-27-2011, 10:53 PM #19
Yes there's a ton of low-pressure chillers out there. New ones are being installed and started up every day.
I'd never advocate pushing in a motor starter or contactor, and definitely not two contactors at the same time. Part-winding starters are there for a reason, and they are usually applied on large HP compressors and motors. I don't want a screwdriver being the only thing between my hand and 460volts/200+amps.Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
"It's called the american dream because you have to be asleep to believe it" -George Carlin
"A nation of sheep begets a government of wolves" -Edward R. Murrow
"I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
Buy american made goods & support locally owned businesses!
11-28-2011, 09:25 PM #20
- Oct 2011
- La.
- 211
This is the problem when residential service techs start to work on larger equipment. I will never push a contactor in by hand. I have seen the outcome of it and you can not do that in a safe manner. I have gone behind other service techs that were severly burned on their hands and had to have metal removed from their eyes because of this practice. Take the time to do the job safe and be able to show up tomorrow to work again. GOOGLE ARC FLASH VIDEOS AND YOU WILL THINK TWICE ABOUT HURRYING IN THE FUTURE!!
04-30-2012, 02:07 PM #21
Yup. As I saw on a poster once, "ELECTRICITY IS A VENGEFUL B***H, NOT TO BE TRIFLED WITH".
The one time that you run across a dead short or a like problem in a motor, as you make the contact at the contactor...that can change your life. For that matter, how many of us are religious about wearing eye protection? I wish I could say that I never forget to put them on. Burnt hands would be bad but not comparable to losing your sight.
04-30-2012, 05:43 PM #22
- Sep 2006
- River Forest IL
- 70
A-men on the Arcflash
Everyone in this trade-field AND office-should have to go through arcflash training. Heck-I think everyone should have at the minimum OSHA 10 training. Lots of ways to get hurt/killed. Field personnel need to know the risks and how to avoid them, office personnel need to know the same so they know better than to question the field when it comes to safety concerns. We've all been there though, take a shortcut 'cause we want to get in/out-I'm as guilty as any. I had an apprentice question not too long ago me on why I was checking power in to a unit after I had shut the disconnect off. I told him (1.) a disconnect is a switch, and all switches eventually fail, and (2.) Had I not checked it and it was bad-it wouldn't have been the first time I got shocked, but it could have been the last.
04-30-2012, 08:26 PM #23
[QUOTE=will smith I had an apprentice question not too long ago me on why I was checking power in to a unit after I had shut the disconnect off. I told him (1.) a disconnect is a switch, and all switches eventually fail, and (2.) Had I not checked it and it was bad-it wouldn't have been the first time I got shocked, but it could have been the last.[/QUOTE]
Three weeks ago I was changing out a burnt stepdown transformer. I hit the disco only to find the switch had failed on the middle leg. Never saw that before, heard about it but never had it happen to me. You can't check for power too carefully.
