    ICP Nomenclature
    Looking at some ICP unit heaters, cannot find BTU input, output(label torn). I was able to get M# UHA250NS Can i safely assume the 250 refers to btu;s 250,000. Cracked heat exchangers and I will need to quote replacements.
    Oct 2010
    Utah
    I would just quote new units of the brand you like and trust and size it to the space it is serving, original units might not have been sized right or derated correctly hence the cracked heat exchanger.
    Good points thanks for the reply brett
