Results 1 to 13 of 13
    Las Cruces, NM
    Hmm
    I just moved into a new home with a roof mounted 12SEER Comfortmaker unit. Everytime the burner kicks in there is there annoying high pitched squeal coming from the walls where the gas line runs.
    Any suggestions on what could be causing the noise in the gas lines and a possible fix?
    Mar 2001
    noise
    Call a service person ASAP. It may not be the gas lines, but take no chances!
    Dec 2001
    Chicago, N/W burbs
    could be a regulator problem either at the furnace or the meter, and you hear it through the pipes.
    R2B4BTU
    burlington county n.j.
    see if noise is worse down by gas meter if it is call gas co. if not call heating co. have heard some gas meters that were very LOUD.
    Apr 2002
    NW Indiana
    I'm curious, would you know if the gas piping happen to be
    C.S.S.T.? (corrigated stainless steel tubing)
    In any event it is something you will need to call some people in.
    "The Bitterness of poor quality remains long after the sweetness of low price is forgotten"
    Ask installer to check connector size at unit...may be undersized or if at meter may be regulator.
    Rapid City, SD
    I'd put my money on a flex line that's too small.
    As someone mentioned earlier on this site, they call them the "moose call".
    No matter what you need to have it checked out, your safety is worth it.
    New Hampshire
    As others have said, undersized corrugated stainless steel tubing (CSST).
    S.E. Pa
    Cool undersized gas lines
    Whistling is usually caused by gas lines undersized for the load. CSST is notorious for this simply due to the corrgugations but copper and iron will do it, too. Have a technician not only check it out but assess the meter's Cubic Foot per Hour rating compared with the total BTU load on the house and check the regulator at the meter. If this is a medium pressure system, there will be a regulator indoors to check as well.
    HTH
    Jun 2000
    WYO
    Elk make the same sound. Not Moose.
    Sounds like,
    Wherrrrrhhheeeeeeeeeeeeeeeeeeeeeerrrrrreee.
    Too small of corregated gas line.
    never say never
    Rapid City, SD
    Oh yeah? Maybe it was a sick moose! lmao
    Mar 2001
    noise
    I only make that sound on special occasions.
    - high pressure, small orifice!
    whistling gas lines
    are the gas lines the stainless flex lines like gastrac or tracpipe? if the line is too small then it will definitely whistle with gas trac or tracpipe, also if there is a valve partially closed, also, I have seen houses piped with steel pipe and the gas flex connector be too small and whistle, so check all of those
