Results 1 to 13 of 18
    First, a big Hello to all of you and a big thanks for shareing you knowledge and time.
    My 10 y/o heat pump has given up and Iam in the process of getting it replaced. I have decided on a Trane system and have gotten 3 quotes from local dealers. I have no idea what is a reasonable price and would like to get some feed back on the middle quote to see if Iam getting a new one ripped or if it seems reasonable to you. I would greatly appreciate your opinions.
    This is a 2600 sq ft cinderblock home in Central florida that faces south. The J manual calculations call for a 4 ton unit.
    The Proposal:
    Removal and disposal of old unit
    New electrical disconect
    New insulated refrigerant lines
    Build new air handler stand with 3/4 inch plywood and insulate inside with 1.5 inch ridged duct insulation.
    New ceiling mounted filter back grille and return duct.
    Build new 1.5 inch ridged fiberglass supply and return plenum.28 x 12
    240-120 CM surge device
    New condensate discharge line with emergency auxiliary overflow device
    Wet switch ( Have no idea what this is)
    Polymer pad for condenser with "extreme kit" ?
    Verify duct condition and seal if needed.
    One 4 ton Trane XL19i 2TWZ9048B
    One Variable speed air handler TWE049E13 FB
    One programable ( super duper ) thermostat
    2 year satisfaction garantee and 10years parts .
    Extended 10 year warranty- for labor and service calls is xxxxx extra
    Perfect fit 5 inch media filter is xxxxx extra
    Cost without the 2 options above is xxxxxxxxx
    Needless to say I GASPED! and told my son he is not getting a car after HS
    Is this reasonable?? Please help with your feed back. (No pricing, due to site rules )
    [Edited by senior tech on 02-14-2006 at 07:27 AM]
    Pricing questions are not allowed on this forum.
    But since you asked, that is significantly less than I would charge, but there wouldn't be any ductboard.
    Thank you Mark . I have had the oppurtunity to read several of your replies to other readers questions and have come to respect your opinion as your replies are inteligent , focused and to the point. I was not aware of the pricing issue.
    I sold the exact system, except for a gas furnace and coil, for almost twice that.
    "It is what it is."
    Lancaster PA
    They must be slow doing it that cheap.
    Get the extended warranty.
    SW FL
    Hmm FL Rates
    FL= Cheap ! $ mentioned = F A I R ! !!
    MOD will be along soon to delete $x,x00
    if jvega4 does not amend his original post.
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
    A hearty Thank You to all those that responded, I appreciate your feedback. Iam not accostumed to throughing around xx or so casualy, takes me a lot of hard work and time to make that kind of money so I decided to ask those that know way more than me about this if I was on the right track.
    Will amend.
    [Edited by senior tech on 02-15-2006 at 07:57 AM]
    Talking
    Too late, Senior tech beat me to it
    Feb 2005
    Richmond
    Hey did you post this question on the GardenWeb HVAC forum? I did respond to your question there. But, in my opinion, seems like the company is doing the right things for a new unit. I say go for it!
    Lancaster PA
    Re: FL Rates
    Then the 19i is alot cheaper then I thought.
    SW FL
    Re: Re: FL Rates
    Suffice it to say,
    I would guess
    ... wholesale FL rate is NOT the same as IN or PA or ...
    VOLUME = Le$$
    Designer Dan
    Lancaster PA
    Re: Re: Re: FL Rates
    [QUOTE]Originally posted by dan sw fl
    [B]
    VOLUME = Le$$
    Say that again, I couldn't hear you, my volume wasn't turned up.
    J/K
    Yeah, that's waaaay too much. I'm sure you can find some guy working out of a station wagon to hack you a system in for a lot cheaper. Then you can pay the original bidder to come back and clean up the mess.
    "Why must I lose to this idiot?!"
    Chess Master Aron Nimzovich, after jumping on the table...
