Results 14 to 26 of 42
Thread: Dimming lights
    It is york Stealth HP, i don't know how it shifts
    About weak ground: doesn't it use 2 hots and no ground?
    A stealth stops and reverses rotation.
    It could be a weak start coponet.
    Or trouble with your electrical system.
    Have your installer/ service tech check the unit, and if its fine call an electrician.
    Feb 2005
    Dothan, Al
    alex
    As others have stated,the only way to know for sure is to contact an electrician. You may have too small wire going to outdoor unit, or a loose connection somewhere, maybe on the breaker itself. May not be anything to be concerned about, but you won't know for sure until it is checked out.
    Definitely not a ground problem.
    Richard
    Jul 2001
    Have you had the annual maintenance performed on you electrical panel?
    Jul 2005
    Wouldn't be surprised if a wire terminal is loose under the breaker. Wire ends are stripped and put into a screw type connection arrangement. These screws sometimes come loose and cause all sorts of problems.
    Aug 2005
    Florida
    Howdy,
    Instead of assuming its in the panel, how about having a tech come out and rule out the c/u? That way the guy isnt paying for two service calls if he calls an electrician first. It may only be worn contacts on the second stage contactor that's causing the problem, then again maybe not. Wont know until its looked at.
    It wouldnt be a bad idea to have it serviced anyways if its been awhile since it was professionally gone thru. May be some other things that need attention you dont know about that someone may find when the trained eye is applied.
    If after the sys been gone thru and it is ruled out as nothing wrong with the a/c sys, then it would be logical to have an electrician have a look and do a PM on the panel....
    Just my .02.......l8r
    Apr 2004
    NJ
    Cool
    Did it always do this? If so, your service capacity may be on the low side so that when the compressor reverses, the additional amp draw is taxing the panel. Does it happen all the time, or only when you're using an electric stove, clothes dryer, etc. If it is something that recently started, the start components probably are on the way out.
    If it was always like this and doesn't trip the breaker or cause it to get hot to the touch, as a loose terminal would cause (in addition to a burnt up wire), it is probably an under sized service panel.
    Maryland's Eastern Shore
    Alright, I assumed. But, really an HVAC service technician needs to look over the equipment once a year and now would be a good time. Being that it buzzes for only a short period at the beginning of the second stage it would lead me to believe a motor load was having difficulty because only motor loads have a large in-rush amp draw, plus the overcoming of LRA. Maybe worn second stage contacts, maybe a failing start component.
    [/B][/QUOTE]
    If it was always like this and doesn't trip the breaker or cause it to get hot to the touch, as a loose terminal would cause (in addition to a burnt up wire), it is probably an under sized service panel. [/B][/QUOTE]
    It's brand new had AC unit replaced with a HP, not sure if it was doing it before
    Jan 2003
    local power company
    Call your local power company you might have low votage or something they might check it for free.
    regards,
    kevlin
    Kansas City
    If its brand new call the installer back out. He can check for loose connections, amp draw, and check wire size and might try changing the breaker. Its not a ground problem.
    Jul 2005
    Here's why I simply said it was the terminal strip. It's not popping the breaker, a loose wire will cause arching as he describes by the noise, the arching will cause carbon to form, which creates resistance which will cause more current, which will cause more heat. You always check the simpliest things first.
    May 2005
    Dont a 40 amp breaker seem a little small for a 4.5 or 5 ton heat pump?
