Results 14 to 16 of 16
    Not in Iran
    Arrow
    Quote Originally Posted by Phisher View Post
    You would be correct if they were freezing the whole pipe. However this procedure calls for freezing a short section of pipe.
    mlkwal1, What size line are you working on?
    i am working on a 4 and 6 inch pipe., they want to change the butterfly valve
    on the discharge side of the pump.,
    sanman, if u THINK about it., if u have a closed loop with no play, yes the pipe would bust,
    however , if u freeze a small section of a pipe, the water will freeze then expand, but only freeze that section, .,
    i was thinking about this product
    www.pipemanproducts.com
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Jul 2001
    Southern NJ
    We have a "cold shot" by general I think. We've used it on a few jobs. It's worked well. We freeze two spots, one on either side of the repair we're doing and then drill a test hole to make sure it's plugged.
    It only works on water that isn't moving and our kit only goes up to 3" pipe. The one time we used it on 3", it took 45 minutes to freeze completely and we had a spare bottle of CO2 on hand just in case we ran out.
    After we freeze the pipe, and drill the test hole, we work like maniacs to get two valves installed for fear that the ice plug might fail...it hasn't yet.
    Ryan
    Maintenance Guy
    naysayer, skeptic, conspiracy theorist
    Mar 2011
    Los Angeles, CA
    Talking
    Quote Originally Posted by mlkwal1 View Post
    Got it..thanks!
