Results 1 to 8 of 8
    Nj Pa De
    york ycw recip manual
    Does anyone have a manual for the ycw recip chiller.I'm looking for compressor rebiuld manual, something hopefully showing valve replacement procedure and torque specs. thanks.
    cant make this crap up
    Jersey
    how about the rest of the model number?
    Nj Pa De
    I know i shouldve had it all, my notes got wet . i do have full compressor model ZB6W1-E46-505 thanks . water cooled.will have entire # tommorrow
    Somewhere in the world.
    This should be the book that you need. The spec's for the compressor is in hard copy only unless someone else has it in PDF would have to scan it.
    Attached Files Attached Files
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Nj Pa De
    thanks york56 , i do have parts of this manual.Unfortunately it doesnt show any service info.I'm hoping a coworker has specs i need.If u or anyone has torques and the procedure for changing the suction and discharge valves.I have done them,lots of little springs.Just wondering what yorks procedure is, any tricks? thanks again
    Will look up the part # you gave for the compressor and get back to you with the spec's.
    After looking at your compressor m/n this is the correct IOM and parts book for replacement parts.
    Nov 2011
    Question York YCWZ77
    Hi,
    I am new to this forum and am trying to find the chiller performance data for a YCWZ77JMO chiller, kw/ton, etc.
    Much Appreciated!!!
