Results 1 to 13 of 24
    I can't seem to find my install files anywhere, and need to reload problock. Does anyone have it? Not sure where I can get it again since stonet is gone.
    Oct 2005
    The .lic file? Or the installation files?
    The actual install files. I downloaded the install .exe from stonet years back, but since they are gone, I cant do that anymore.
    I have never used any other program on the BCN8000 system, so I am not sure if there is anything else better or not.
    Oct 2005
    Eclypse has problems, I would only use it as a last resort.
    If you can run PSI somehow then do it,
    Problock is expensive, and has virtually no support, as you can see..
    If it is the database backup features you are looking for then use a Signal pkg if you have one.
    Oct 2005
    I coul dmail you the install file, it's about 24 megs,,it won't help you though unless you have the .lic file registered, the old install you have was a little different it had a trial version on it, the new one doesn't.
    I have the .lic file already. Sent you an email as well.
    Oct 2005
    Should have mail Code,
    It is a link to a server that I uploaded it to,
    Don't paste the link here, I will take it down after I know you get it.
    Got it, thanks!
    Working perfectly!
    Oct 2005
    That was quick ?
    download took less than a minute, and it took me about 5 mintues to "fix" it. Stonet did not really try to hard...
    Oct 2005
    Fix what ?
    What did you fix ?
    Oct 2005
    Oh you mean the secret code thing, yeah it was a piece of cake.
    I too need a working copy of Eclypse Pro Block. Although i can edit and create blocks through a Niagara format i need to back up all my LNC's (GCM's)
    Can you help?
