    Practically Canadian ehh.
    I found some of these installed in a building. The customer wants us to tie them in to his Summit since they are Lon. Just curious here, what software does Staefa use to configure these? Is it something easily available or are they as tight as Trane?
    -kw
    Jul 2005
    Wisconsin
    They can be configured from the shadow object in Tridium, I'm not sure if there is any other way to make changes through any Staefa software...you should have access to most points through the nci's and nvi's through any lon software.
    Nov 2005
    If they are LonMark, not just Lon you must have good documentation and you can configure it thru SNVT/nci-s,
    I was just wondering what Siemens uses to configure the controller.
