Results 1 to 13 of 19
Thread: Duct Problems
11-17-2011, 05:38 PM #1
Duct Problems
Today i had a water source heat pump feeding a classroom and 3 offices. It has a main trunk line with 8" taps coming off of it. There are a total of 7 taps on this unit. 4 for the classroom and 1 for each office. Well the problem i am having is the one diffuser nearest to the unit isn't putting out hardly any air. I pulled the duct off and inspected inside the duct. At this point in the duct, it is like there is a dead spot. The air is just turbulating around the opening. This duct tap comes off right after the flex connector. It is the first fed. The diffusers that come off further down the main get plenty of air. Why is this? What can i do to the ducting to fix this problem? The office with the problem has the stat. So it is causing no heat or cool to go into the room. So it either burns everyone out or freezes everyone out depending.
Thanks for the help!J. King
11-17-2011, 05:42 PM #2
Too high of velocity, the air just blows on by. Add a scoop.
Oops, hope that aint DIY. If so a mod can remove and spank me.If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
11-17-2011, 06:26 PM #3
How many people have messed with the downtream dampers to get more/less heat or cooling in their office?
A simple professional re-balance may help things. Either that or it may not have been properly balanced in the first place.___________________________
-supertek65Chicago is an indian word for stinky!!!!!!
11-17-2011, 07:25 PM #4
How far away is this duct from any changes in direction?
Is there a long section of straight duct before the tap or is it right after a change in direction?
Do you have shoe taps?
11-17-2011, 08:11 PM #5
Yea i was thinking that, but i just didn't know how much that would help. I haven't used them that much. I heard something from a sheet metal guy stating that the air is more even at the end of the trunk.
Actually every damper is open all the way down the trunk line.
The main duct just comes straight off of the heat pump, goes into a flex connector, and is just a straight run all the way to the end cap. The duct doesn't change directions or switch sizes. The tap with the problem is right up next to the discharge of the unit. There is no long straight run before the taps.
Shoe taps? Are they taps with scoops?J. King
11-18-2011, 07:45 AM #6
Might want to relocate the takeoff further down the duct where there is less turbulence and and the velocity has slowed, probably the easiest solution.
11-18-2011, 08:47 AM #7
11-18-2011, 09:06 AM #8
- Sep 2011
- Vancouver, WA
- 183
11-18-2011, 09:17 AM #9
Professional Member*
- Jan 2001
- Pamnyra VA.
- 701
Is there a transition in duct size anywhere along the main trunk?There should be after a few taps are taken off.This will add pressure to your outllet.
11-18-2011, 01:56 PM #10
- Jun 2010
- Philadelphia PA
- 2,139
Gibby, I like this suggestion
11-18-2011, 03:36 PM #11
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
+1
11-18-2011, 08:46 PM #12If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
11-18-2011, 09:21 PM #13
No static man
Sounds like you have no static pressure. Too many openings or too many air exits to allow for static pressure to build up and push the air out of the closest registors. Close down some of the dampers until you get static pressure in the trunk. I Should think you would need a 1/2 inch or so of pressure at 2/3 down the trunk run, on a unit that size.
