    Nov 2011
    Liebert 3000 humidifier
    hi all, i have a libert 3000. Humidifier bulbs work when i run it in diagnostics, but in normal cycle pan fills but bulbs never come on. What could be cause of this problem?
    Domcort.
    This is the Ask Our Pro's forum. In order to post advice here, you must have verified qualifications and have been approved by the AOP Committee.
    Feb 2011
    Sacramento, CA
    Did you check the small high temp switch on the bottom of the pan? It is there in case your pan runs out of water for some reason.
    I have done so much with so little for so long, that now I can do almost anything with nothing at all.
    Nov 2011
    thanks GoColts
    Thanks GoColts, checked sensor on bottom of pan. it was a little loose. put it back in place and secured it. Humidifier cycles on perfect now.
