    Bethlehem PA
    compressor paint bubbling
    Anybody have an idea why the paint would be bubbling on the heads of Carlyle 06d compressor on a Liebert? hp 225 suction pressure 60, 10 degrees subcooling, 12 degrees sh (maybe a little low), 172 degree discharge pipe temp. water cooled. Thanks
    Apr 2008
    VA
    How old is compressor? SH is a little low but sounds like the powdercoat didn't adhere properly and under constant heat load (172F) is causing the bubbling. How bad is the bubbling?
    Dec 2009
    Montreal,Qu้bec, Canada
    Is the bubbling only on the heads? What does the air ambient look like? Could be a vinegar or acidic environment.
    Jul 2009
    In a mechanical room....
    Is it only on one head?
    Shoot the heads with your ir gun is there a head that is much hotter than the others?
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    Dec 2003
    Northern VA
    Is it the original or a rebuilt?
    Not all rebuilders give as much attention to prepping for the repaint as others.
    None are as good as the factory.
    If it is circuit#2 oil drips from #1 could foul the paint on #2.
    "Iron sharpeneth iron..."
    Feb 2011
    OH
    take temp of top of comp head with infered gun temp on part of shows hoter in areas or hole head to hot .sounds like valves and valve plate ,
