Results 1 to 8 of 8
Thread: ductwork in attic
02-06-2006, 03:54 PM #1
- Feb 2006
- 4
should the ductwork in the attic be suspended above the insulation in the ceiling or placed directly on top of the ceiling joists and buried in the insulation when the attic is insulated? I am building a new house, thanks for any help you may have. I am insulating the attic with 15" of cellulose
02-06-2006, 04:19 PM #2
- Aug 2005
- Navarre Florida
- 131
12" up from sheetrock is code for us
02-06-2006, 04:20 PM #3
i always hang it.
FILL OUT YOUR PROFILE!!
02-06-2006, 04:27 PM #4
- Dec 2005
- Waubun, Mn
- 30
Ductwork
I always run ductwork above the insulation, supported at least every 4 or 5 feet, if there is enough attic space. This helps prevent other trades from running their wires and pipes on top of the ducts and damaging the duct work.
The job looks cleaner and with flex duct it allows more room for a nice gradual sweep down to the boots, which helps reduce air restrictions.illiterates untie!!!!!
02-06-2006, 04:44 PM #5
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
Code here is above insulation.
02-06-2006, 05:49 PM #6
- Feb 2006
- 4
thank you, I appreciate that, do you feel the ductwork is better buried in the insulation or suspended above the insulation?
02-06-2006, 05:55 PM #7
Banned
- Aug 2002
- 18,836
Florida study showed that the ducts ,with R-6 insulation ,displaced more ceiling insulation than it replaced(with the Duct R value) leaving the ceiling with less R value,hence the code.
Now if you could "bury' it under the full R value of ceiling insulation,it might be better,otherwise ,I'd do as Clint Eastwood,
"Hang Em High".
02-06-2006, 05:57 PM #8
- Feb 2006
- 4
thanks all for you help, I do appreciate that
