    How do I get rid of air in the hotwater heating system. I can hear rushes of water going through the pipes also banging sometimes.
    go to every bleed port, crack em open and let it flow. expect to get water out, i will genraly bleed out 1/4 cup per point of water.
    Jul 2002
    St Paul, Minnesota
    Don't forget to bring the pressure back up after bleeding.
    Nov 2005
    netherlands\europe
    Hmm
    Sometimes you will find the air trapt in a spot witch is of some distance from the bleeding point. And then sometimes it helps to stop the flow in that part of the system, that can be done by 1 stopping the pump
    2 stopping [closing] the radiators in that section.
    Sometimes it helps to heat up the complete system, stop it wait a couple of minutes and bleed it again.
    If that all din't help, try to get as much flow as you can trough the noisy section, hopefully the trapt air takes a rollercoaster ride to the bleeder.
    But how did the air became a problem in the first place?
    Is the position of the vessel good? are you pumping away from the vessel?
    Dec 2001
    Chicago, N/W burbs
    There are so many different types of systems with different piping arrangements that a concise answer would be quite difficult to post here. You may also have a system that was never piped properly in the first place.
    A call to a local heating contractor who has a "wethead" on staff would be your best bet.
    R2B4BTU
