Results 1 to 13 of 17
    Nov 2011
    Cracked Heat Exchanger on Lennox Furnace
    We had a technician come out today to diagnose a problem with our furnace and upon inspection he noticed that there was a crack in the heat exchanger and the blower control board needs replacing (the original problem). The furnace (Lennox G26Q3/4) was installed around 1996. According to the tech, the heat exchanger is under lifetime warranty and we would have to pay for the blower control board. We would have to pay for the labor which he said would take a day to do. Does it make sense to replace the heat exchanger or should the whole furnace be replaced. I was also reading in another thread and it was mentioned that carrier gave an allowance if the heat exchanger needed to be replaced. Does Lennox offer something similar? Thanks for the help.
    chicago suburbs
    apparently math is not my strong suit.
    FILL OUT YOUR PROFILE!!
    Quote Originally Posted by tinner73 View Post
    i'd find out why the heat exchanger cracked in only 6 years.
    excelled a math did you?
    2011-1996=15
    have them check to see if lennox has a program to transfer warranty $ to replacement $
    chicago suburbs
    hahahahahahahaha!!!
    my bad read it to fast.
    just pokin' you,
    I had too read it 3 times to make sure I hadn't missed something
    Quote Originally Posted by cisco1 View Post
    This is a Pulse furnace, I believe.
    If so, there are minimal to NO parts available.
    Do NOT pay for the repair.
    there is a replacement program that has an incentive towards a new Lennox furnace. Your tech should know this and have the info or the salesperson for the tech will inform you of the details.
    Bsmith816.
    This is the Ask Our Pro's forum. In order to post advice here, you must have verified qualifications and have been approved by the AOP Committee.
    Quote Originally Posted by pacnw View Post
    G26 isn't a Pulse.
    No labor help from Lennox. So you would have to pay labor, freight and for the board. At 15 years, might be wise to for a new one.
    If you have any reason to doubt him, get a 2nd opinion. Hopefully he is honest but we've got some dealers around here whose techs will tell the customer anything to get a sale.
    I would agree
    with BL by the time you pay for board and labor you are behind the 8 ball, you still have major components on an older system that are stressed.
    May 2008
    Missouri
    We just had two of those same model furnaces with cracks last week. If it was JUST the heat exchanger, then I'd recommend replacing, but combined with the board, then the total cost would be too high IMO anyway. But very common problem with the Lennox G26 in my experience. But frankly, I'd keep this in mind in determining what brand I'd replace with!! Sadly, nobody tells the customer how many heat exchangers it takes to last a "lifetime".
    P.S. One was a 4 cell (100k) and all four cells were cracked, the other was a 3 cell (75K) and had only one cracked (now anyway).
    Quote Originally Posted by wahoo View Post
    Or the correct size with propper airflow and gas pressure to make it last.
    May 2008
    Missouri
    Both of these G26 units had been on our pre-paid Maint. plan since installed. So they had been taken care of. We've had numerous other G26 units do same thing.
