    Does anybody know of a manufacturer, distributer, etc for residential wall units that heat and cool with water. I used to work in a hotel and thet used them there, but no one I talk to has any idea what I'm talking about. They are basically a small air handeler that fits in the wall with 2 heat exchangers, blower, and zone valve. Any info would be helpful
    Grottoes VA
    Try First Company, chiller coil and hot water coil.
    Oct 2005
    Hmm Power plant
    The Hotel must have had a power plant and the units just provided air over a heating or cooling coil. Or are you talking about a split ductless system?
    No there were several large boilers and chillers to provide the hot water and cold water. I would like to try this setup for residential if economical and even availble. The water from the chiller usually was around 50-55 degress far, by the time it got to the units and it seemed to work well. My ground water is that temp or I think if I bury coils about 10 ft I should be able to use a closed loop. I'm not sure if I what type of boiler or maybe even an outdoor corn boiler, not sure, shouldn't matter as long as I can get hot water. I know I have a lot of options there. I just would like to find the room units.
    Oct 2005
    HVAC
    Any supply house can order you this.
