Results 1 to 2 of 2
    NJ
    I hear a lot of people talking about negative pressure causing problems with furnaces not running correctly.
    How can u tell if a house has negative pressure on it.
    I also read on a prior post that is could make a limit pop on inducer motor. How is that possible.
    I assume your talking about 80+ furnaces. They are really natural draft, the vent pipe should be negative. if the home is negative, it can prevent the flue from venting properly and trip the over temp switches.
