Thread: glycol question
    villalba,p,r
    hi guys: I need the glycol freezing point.Someone help me.
    Jan 2002
    New Hampshire
    It isn't used straight, and
    the slush point and burst point vary with the per centage.
    Noel
    Apr 2004
    Unhappy freezing point
    The freezing point depends on the type of glycol. You need a refractometer to measure the actual freeze point which sounds expensive, but you can use the same tool you use to check your antifreeze in your car's radiator.
    You can buy a tool called a refractometer for checking freeze points
    Nov 2003
    Boston
    Found a link with charts for you:
    http://www.ashchem.com/adc/chemicals...=3&is_header=N
    Edited by powerhead on more than one occasion
    Apr 2005
    where the beer flows like wine
    orland, have checked your local mamabicho charts?
