    Jan 2006
    Harrisburg PA
    furnace is shutting down after 25-30 secs.....is the transformers output enough to cause this problem?
    Kingston, Ny
    Call your local HVAC guy or you may end up with more problems than you think you have.
    Happiness is the only good. The time to be happy is now. The place to be happy is here. The way to be happy is to make others so.
    -Robert Green Ingersoll
    Jan 2006
    sounds like something you should have your hvac contractor diagnose,we dont do online service calls it could be any number of things.
    Weak or failing batteries in the digital volt meter can give you a lower voltage reading.
    Jan 2006
    change the transformer
    Forum Rules
    The site rules are why professionals on this site can not help you.
    If you are a professional in this field, please fill out your profile and register, they you may join us in the professional areas.
    thread closed
